Datasheet Texas Instruments UCC37324DGNR — Даташит
СерияUCC37324
МодельUCC37324DGNR
Двойные высокоскоростные драйверы MOSFET с пиковым током 4 А на стороне низкого напряжения 8-MSOP-PowerPAD 0–70
UCCx732x Dual 4-A Peak High-Speed Low-Side Power-MOSFET Drivers datasheet
PDF, 1.3 Мб, Версия: I, Файл опубликован: 29 июл 2016
15 предложений от 15 поставщиков
IC GATE DRVR LOW-SIDE 8MSOP. Low-Side Gate Driver IC Non-Inverting 8-MSOP-PowerPad. PMIC - Gate Drivers
UCC37324DGNR
53 ₽
UCC37324DGNR
54 ₽
Рутоника
UCC37324DGNR
69 ₽
UCC37324DGNR
152 ₽
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
Маркировка37324
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
Channel Input LogicNon-Inverting
Fall Time15 нс
Input ThresholdCMOS,TTL
Input VCC(Max)15 В
Input VCC(Min)4.5 В
Количество каналов2
Package GroupMSOP-PowerPAD
Peak Output Current4 A
Power SwitchMOSFET,IGBT,GaNFET
Prop Delay25 нс
Rise Time20 нс
Special FeaturesDual Non-inverting Outputs,Hysteretic Logic
  • Evaluation Modules & Boards: UCC3895EVM-001
    UCC3895 Evaluation Module
  • Synchronous Rectifiers of a Current Doubler
    PDF, 207 Кб, Файл опубликован: 27 фев 2003
    Driving a current doubler synchronous rectification output stage can be a very complex task, especially for a phase shifted full bridge topology. However, using the A and B outputs of the UCC3895 along with the UCC37324 dual 4-A MOSFET driver, direct PWM control of a synchronous rectifier current doubler output stage achieves. This technique provides the proper gating and timing signals necessary
  • Semiconductors > Power Management > MOSFET and IGBT Gate Drivers > Low-side Driver
На английском языке: Datasheet Texas Instruments UCC37324DGNR
