Datasheet Texas Instruments V62/12622-01YE — Даташит
| Серия | TMS570LS20206-EP |
| Модель | V62/12622-01YE |
Усовершенствованный продукт: 16- и 32-битный RISC-микроконтроллер флэш-памяти 337-NFBGA от -55 до 125
TMS570LS20206-EP, TMS570LS20216-EP 16/32-Bit RISC Flash Microcontroller datasheet
PDF, 967 Кб, Версия: A, Файл опубликован: 2 авг 2012
5 предложений от 5 поставщиков , MCU 16Bit/32Bit Hercules TMS570 ARM Cortex R4F RISC 2048KB Flash 1.5V 337Pin NFBGA Tray | |||
| V62/12622-01YE Texas Instruments | 2 994 ₽ | ||
| V62/12622-01YE Texas Instruments | по запросу | ||
| Pin | 337 | 337 |
| Package Type | GWT | GWT |
| Industry STD Term | NFBGA | NFBGA |
| JEDEC Code | S-PBGA-N | S-PBGA-N |
| Package QTY | 90 | 90 |
| Carrier | JEDEC TRAY (5+1) | JEDEC TRAY (5+1) |
| Маркировка | S20206ASGWTMEP | TMS570 |
| Width (мм) | 16 | 16 |
| Length (мм) | 16 | 16 |
| Thickness (мм) | .9 | .9 |
| Pitch (мм) | .8 | .8 |
| Max Height (мм) | 1.4 | 1.4 |
| RoHS | See ti.com |
- Triangle/Trapezoid Wave Generation Using PWM With Hercules N2HETPDF, 476 Кб, Файл опубликован: 1 май 2015
This application report illustrates how to generate various forms of triangle and trapezoid waves using the versatile programmable high-end timer (N2HET). The examples can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET registers as well as basic system s - Sine Wave Generation Using PWM With Hercules N2HET and HTUPDF, 371 Кб, Файл опубликован: 12 май 2015
This application report illustrates how to generate sine waves using the versatile programmable high-end timer (N2HET) and its companion data transfer unit (HTU). The code example can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET and HTU registers as we
Серия: TMS570LS20206-EP (4)
- S5LS20206ASGWTMEP S5LS20206ASPGEMEP V62/12622-01XE V62/12622-01YE
- Semiconductors > Space & High Reliability > Microcontroller > Performance MCU > Safety Products
V62/1262201YE, V62/12622 01YE
Купить V62/12622-01YE на РадиоЛоцман.Цены
