Datasheet Texas Instruments SN74AVC2T45DCUTE4 — Даташит
СерияSN74AVC2T45
МодельSN74AVC2T45DCUTE4
Двухбитовый приемопередатчик с двойной шиной питания, настраиваемым преобразованием напряжения и выходами с 3 состояниями 8-VSSOP от -40 до 85
SN74AVC2T45 2-Bit, Dual Supply, Bus Transceiver With Configurable Level-Shifting and Translation datasheet
PDF, 1.1 Мб, Версия: L, Файл опубликован: 18 май 2017
Package TypeDCU
Industry STD TermVSSOP
Width (мм)2
Length (мм)2.3
Thickness (мм).85
Pitch (мм).5
Max Height (мм).9
3-State OutputYes
Approx. Price (US$)0.23 | 1ku
Bits(#)2
F @ Nom Voltage(Max)(Mhz)100
Gate TypeTRANSCEIVER
ICC @ Nom Voltage(Max)(mA)0.0008
LogicTrue
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)12/-12
Package GroupVSSOP
Package Size: mm2:W x L (PKG)See datasheet (DSBGA)
Schmitt TriggerNo
Special FeaturesIOFF
Dual Supply
Translation
Sub-FamilyDual Supply Translator
Technology FamilyAVC
VCC(Max)(V)3.6
VCC(Min)(V)1.2
Voltage(Nom)(V)1.2
1.5
1.8
2.5
3.3
tpd @ Nom Voltage(Max)(ns)3.1
2.6
2.4
2.2
RoHSНе совместим
  • Evaluation Modules & Boards: BOOST-CC2564MODA
    Dual-mode BluetoothВ® CC2564 module with integrated antenna BoosterPackв„ў plug-in module
  • Evaluation Modules & Boards: DLPLCR4500EVM
    DLPВ® LightCrafterв„ў 4500
  • Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
    Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i
  • AVC Logic Family Technology and Applications (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
    Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control (
  • Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)
    PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AVC2T45DCUTE4
