Datasheet ТI 8607701CA — Даташит
| Серия | CD54HC280 |
| Модель | 8607701CA |
Высокоскоростная КМОП-логика, 9-битный генератор четности/четности/проверка 14-CDIP от -55 до 125
CD54HC280, CD74HC280, CD54HCT280, CD74HCT280 datasheet
PDF, 708 Кб, Версия: D, Файл опубликован: 21 окт 2003
- CMOS Power Consumption and CPD Calculation (Rev. B)PDF, 89 Кб, Версия: B, Файл опубликован: 1 июн 1997
Reduction of power consumption makes a device more reliable. The need for devices that consume a minimum amount of power was a major driving force behind the development of CMOS technologies. As a result CMOS devices are best known for low power consumption. However for minimizing the power requirements of a board or a system simply knowing that CMOS devices may use less power than equivale - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HC280 (2)
- 8607701CA CD54HC280F3A
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
