Datasheet Texas Instruments LMT70YFQT — Даташит
СерияLMT70
МодельLMT70YFQT
В±0.1В°C Precision Analog Temperature Sensor 4-DSBGA -55 to 150
LMT70, LMT70A В±0.05В°C Precision Analog Temperature Sensor, RTD and Precision NTC Thermistor IC datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 11 май 2015
Pin4
Package TypeYFQ
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY250
CarrierSMALL T&R
Thickness (мм).42
Pitch (мм).4
Max Height (мм).675
InterfaceAnalog Output
Local Sensor Accuracy(Max)0.36 +/- C
Рабочий диапазон температурот -55 до 150 C
Output Impedance80 Ohm
Package GroupDSBGA
Sensor Gain-5.19 mV/Deg C
Supply Current(Max)12 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2 В
  • Evaluation Modules & Boards: LMT70EVM
    LMT70 Evaluation Module Precise Analog Output Temperature Sensor with Output Enable
  • Wearable Temp-Sensing Layout Considerations Optimized for Thermal Response (Rev. B)
    PDF, 3.6 Мб, Версия: B, Файл опубликован: 23 окт 2018
    This applicationnotediscussesthermalresponseconsiderationsfor IC temperaturesensorsin measuringskin temperaturefor wearableapplicationssuchas fitnessbandsand medicaldevices.It will specificallyfocuson twodevices—the LMT70andthe TMP117temperaturesensors—overthe humanbodytemperaturerange.Thisinformationcan be appliedhoweverto ot
  • SC Temp Sensors Challenge Precision RTDs and Thermistors in Build Automation
    PDF, 247 Кб, Файл опубликован: 21 апр 2015
    Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
  • Temperature sensors: PCB guidelines for surface mount devices (Rev. A)
    PDF, 5.6 Мб, Версия: A, Файл опубликован: 18 янв 2019
    Power hungry electronic components such as CPUs GPUs or FPGAs as well as voltage regulators heat up during operation. Some applications require ambient air temperature measurements while others need to measure the temperature of a nearby component on the PCB. Measuring ambient air temperature with a surface mount technology (SMT) device is challenging due to the thermal influence of other compo
Серия: LMT70 (2)
  • Semiconductors > Sensing Products > Temperature Sensors > Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT70YFQT
