Datasheet Texas Instruments LM3102QMH/NOPB — Даташит
СерияLM3102-Q1
МодельLM3102QMH/NOPB
Синхронный понижающий стабилизатор напряжения 20-HTSSOP, 1 МГц, 2,5 А, от -40 до 125
LM3102/-Q1 SIMPLE SWITCHERВ® Synchronous 1-MHz, 2.5-A Step-Down Voltage Regulator datasheet
PDF, 1.5 Мб, Версия: H, Файл опубликован: 30 июн 2015
Pin2020
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY7373
CarrierTUBETUBE
МаркировкаQMHLM3102
Width (мм)4.44.4
Length (мм)6.56.5
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeCOT with emulated ripple
Duty Cycle(Max)94 %
Iout(Max)2.5 A
Iq(Typ)1 мА
Package GroupHTSSOP
RatingAutomotive
Regulated Outputs1
Special FeaturesEnable,Synchronous Rectification
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)42 В
Vin(Min)4.5 В
Vout(Max)7 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: LM3102EVAL
    SIMPLE SWITCHERВ® Synchronous 1MHz 2.5A Step-Down Voltage Regulator Evaluation Module
  • AN-2218 Precision Current Limiting with the LMP8646 and LM3102 (Rev. A)
    PDF, 109 Кб, Версия: A, Файл опубликован: 23 апр 2013
    This application report discusses how to design the Texas Instruments LMP8646 with the LM3102 voltageregulator and a supercap load application.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • AN-2200 Precision Current Limiting with the LMP8646 and LMZ12003 (Rev. A)
    PDF, 94 Кб, Версия: A, Файл опубликован: 23 апр 2013
    This application report discusses how to design the Texas Instruments LMP8646 with the LMZ12003voltage regulator and a resistive load application.
Серия: LM3102-Q1 (2)
На английском языке: Datasheet Texas Instruments LM3102QMH/NOPB
Публикации по теме
