Datasheet Texas Instruments TL750M05CKC — Даташит
СерияTL750M05
МодельTL750M05CKC
LDO с одним выходом, 750 мА, фиксированный (5,0 В), низкий ток покоя, защита от сброса нагрузки 60 В 3-TO-220 от 0 до 125
17 предложений от 16 поставщиков
IC REG LINEAR 5V 750MA TO220-3. Linear Voltage Regulator IC 1 Output 750mA TO-220-3. PMIC - Voltage Regulators - Linear
TL750M05CKC
59 ₽
TL750M05CKC
156 ₽
Элитан
TL750M05CKCS
636 ₽
TL750M05CKC
Pin3
Package TypeKC
Industry STD TermTO-220
JEDEC CodeR-PSFM-T
МаркировкаTL750M05C
Width (мм)9.02
Length (мм)10.17
Thickness (мм)4.58
Pitch (мм)2.54
Max Height (мм)4.7
Accuracy(%)1
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.42 | 1ku
Fixed Output Options(V)5
Iout(Max)(A)0.75
Iq(Typ)(mA)5
Noise(uVrms)500
Operating Temperature Range(C)0 to 125
Output OptionsFixed Output
Package GroupTO-220
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
Powered LoadFPGA
Microcontroller
Microprocessor
Regulated Outputs(#)1
Vdo(Typ)(mV)600
Vin(Max)(V)26
Vin(Min)(V)6
Vout(Max)(V)5
Vout(Min)(V)5
RoHSНе совместим
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
На английском языке: Datasheet Texas Instruments TL750M05CKC
