Datasheet Texas Instruments TL751L05QD — Даташит
СерияTL751L05
МодельTL751L05QD
LDO с одним выходом, 150 мА, фиксированный (5,0 В), низкий ток покоя, защита от сброса нагрузки 60 В, 8-SOIC от -40 до 125
Datasheet
TSP
7 предложений от 5 поставщиков
LOW-DROPOUT VOLTAGE REGULATORS
TL751L05QD
от 593 ₽
Элитан
TL751L05QD
1 010 ₽
TL751L05QD
TL751L05QD
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Accuracy(%)4
Additional FeaturesEnable
Overcurrent Protection
Thermal Shutdown
Approx. Price (US$)0.20 | 1ku
Fixed Output Options(V)5
Iout(Max)(A)0.15
Iq(Typ)(mA)1
Noise(uVrms)500
Operating Temperature Range(C)0 to 125
Output Capacitor TypeCap Free
Non-Ceramic
Output OptionsFixed Output
See datasheet (CDIP)
Powered LoadFPGA
Microcontroller
Microprocessor
Regulated Outputs(#)1
Vdo(Typ)(mV)600
Vin(Max)(V)26
Vin(Min)(V)6
Vout(Max)(V)5
Vout(Min)(V)5
RoHSНе совместим
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
На английском языке: Datasheet Texas Instruments TL751L05QD
