Datasheet Texas Instruments TMS320C17FNL — Даташит
СерияTMS320C17
МодельTMS320C17FNL
Процессоры цифровых сигналов 44-PLCC от 0 до 70
Digital Signal Processors (Rev. C)
PDF, 1.2 Мб, Версия: C, Файл опубликован: 1 июл 1991
TMS320C17FNL
Pin44
Package TypeFN
Industry STD TermPLCC
JEDEC CodeS-PQCC-J
Width (мм)16.59
Length (мм)16.59
Thickness (мм)4.06
Max Height (мм)4.57
RoHSНе совместим
  • Transferring 16-Bit Data Using the TMS320C17 DSP 8-Bit Serial Port
    PDF, 52 Кб, Файл опубликован: 1 июл 1996
    This application report describes two methods of using an 8-bit serial port to receive a 16-bit data word. The first method uses the Texas Instruments (TI?) TMS320C17 ('C17) digital signal processor (DSP) 8-bit serial port to receive the 16-bit data word. The second method improves the first method by adding a counter to the hardware. This report describes the hardware and software modifications r
  • Interfacing the TLC32040 Family to the TMS320 Family (Rev. A)
    PDF, 116 Кб, Версия: A, Файл опубликован: 1 янв 1988
    INTERFACING THE TLC32040 FAMILY TO THE TMS320 FAMILY APPLICATION REPORT
  • TMS320C1x Evaluation Module Analog Interface
    PDF, 173 Кб, Файл опубликован: 1 янв 1993
    The TMS320C16 evaluation module (EVM) is used to evaluate the performance characteristics of the TMS320C1x 16-bit fixed-point digital signal processor (DSP). This document builds a supplemental analog interface board that provides the analog capabilities commonly used by the DSP chip. This detailed document includes the schematics, the parts list, the cable connections, the power requirements, and
  • Minimizing Quantization Effects Using the TMS320 DSP Family
    PDF, 268 Кб, Файл опубликован: 1 июл 1994
    Due to its discrete nature DSPs represent variables and performs arithmetic functions with a finite word length. This produces three effects: the selection of filter transfer functions is quantized with filter poles and zeros existing only at specific locations in the z plane; the input is quantized; and noise is introduced from DSP multiplication and division operations. This document shows how
Серия: TMS320C17 (2)
  • Semiconductors > Processors > Other Processors
На английском языке: Datasheet Texas Instruments TMS320C17FNL
