Datasheet Texas Instruments LMT87QDCKRQ1 — Даташит
СерияLMT87-Q1
МодельLMT87QDCKRQ1
Автомобильный класс, 2,7 В, аналоговый выходной ток 10 мкА, датчик температуры 5-SC70 от -50 до 150
LMT87/LMT87-Q1 2.7-V, SC70/TO-92/TO-92S, Analog Temperature Sensors With Class-AB Output datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 23 июн 2017
43 предложений от 15 поставщиков
SENSOR ANALOG -50C-150C SC70. Temperature Sensor Analog, Local -50°C ~ 150°C 13.6mV/°C SC-70. Temperature Sensors - Analog and Digital Output
Microfind
LMT87QDCKRQ1
24 ₽
LMT87QDCKRQ1
103 ₽
LMT87QDCKRQ1
LMT87QDCKRQ1
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаBVA
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
InterfaceAnalog Output
Local Sensor Accuracy(Max)2.7 +/- C
Рабочий диапазон температурот -50 до 150 C
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
RatingAutomotive
Sensor Gain-13.6 mV/Deg C
Special FeaturesIndustry standard pinout
Supply Current(Max)8.1 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2.7 В
  • SC Temp Sensors Challenge Precision RTDs and Thermistors in Build Automation
    PDF, 247 Кб, Файл опубликован: 21 апр 2015
    Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
Серия: LMT87-Q1 (2)
  • Semiconductors > Sensing Products > Temperature Sensors > Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT87QDCKRQ1
Публикации по теме
