Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS7924IRTER — Даташит
СерияADS7924
МодельADS7924IRTER
12-разрядный 4-канальный АЦП SAR с мультиплексорными входами и интеллектуальной системой управления питанием 16-WQFN от -40 до 85
ADS7924 2.2 V, 12-Bit, 4-Channel, MicroPOWER Analog-to-Digital Converter With I2C Interface datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 15 сен 2017
Pin16
Package TypeRTE
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Маркировка7924
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
# Input Channels4
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.2 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)1.65 В
INL(Max)1.5 +/-LSB
Input Range(Max)5.5 В
Тип входаSingle-Ended
Integrated FeaturesOscillator
InterfaceI2C
Package GroupWQFN
Package Size: mm2:W x L16WQFN: 9 mm2: 3 x 3(WQFN) PKG
Power Consumption(Typ)0.5 mW
Reference ModeSupply
Разрешение12 Bits
SINADN/A дБ
Sample Rate (max)100kSPS SPS
Sample Rate(Max)0.1 MSPS
THD(Typ)N/A дБ
  • Evaluation Modules & Boards: ADS7924EVM
    ADS7924 Evaluation Module
  • Evaluation Modules & Boards: ADS7924EVM-PDK
    ADS7924 Performance Demonstration Kit
  • Obtaining 17 Bits of Resolution using a 12-Bit A/D System on a Chip
    PDF, 337 Кб, Файл опубликован: 24 июн 2010
    Integrated data acquisition systems can provide many benefits over discrete component designs. Superior performance, power, and cost savings, along with shorter development times, are among these benefits. Features such as integrated programmable gain amplifiers and averaging can provide added resolution. This application note includes information on how to achieve 17 bits of effective resolution
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7924 (2)
На английском языке: Datasheet Texas Instruments ADS7924IRTER
