Datasheet Texas Instruments CD54HC161F3A — Даташит
СерияCD54HC161
МодельCD54HC161F3A
Высокоскоростной 4-битный двоичный счетчик КМОП-логики с асинхронным сбросом 16-CDIP от -55 до 125
CD54/74HC161, CD54/74HCT161, CD54/74HC163, CD54/74HCT163 datasheet
PDF, 469 Кб, Версия: D, Файл опубликован: 13 окт 2003
Микросхема Счётчик, Counter Single 4Bit Sync Binary UP 16Pin CDIP Tube
CD54HC161F3A
1 056 ₽
CD54HC161F3A
3 873 ₽
ТаймЧипс
CD54HC161F/3A
CD54HC161F3A
Pin1616
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
Маркировка8407501EACD54HC161F3A
Width (мм)6.926.92
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Bits4
F @ Nom Voltage(Max)28 Mhz
FunctionCounter
ICC @ Nom Voltage(Max)0.08 мА
Output Drive (IOL/IOH)(Max)5.2/-5.2 мА
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyHC
ТипBinary
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)39 нс
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC161 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments CD54HC161F3A
