Datasheet Texas Instruments MSP430FR2111IRLLR — Даташит
СерияMSP430FR2111
МодельMSP430FR2111IRLLR
Микроконтроллер со сверхнизким энергопотреблением, тактовая частота 16 МГц, 4 КБ FRAM, 1 КБ SRAM, 12 входов/выходов, 8-канальный 10-разрядный АЦП 24-VQFN от -40 до 85
MSP430FR21xx, MSP430FR2000 Mixed-Signal Microcontrollers datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 13 июл 2017
Pin24
Package TypeRLL
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаFR2111
Width (мм)3
Length (мм)3
Thickness (мм).85
Pitch (мм).4
Max Height (мм)1
ADCADC10 - 8ch
AESN/A
Active Power120 uA/MHz
Additional FeaturesReal-Time Clock,Watchdog,Temp Sensor,Brown Out Reset
BSLUART
CPUMSP430
Comparators4
Featuredfr2
Тактовая частота16 МГц
GPIO Pins12
Max VCC3.6
Min VCC1.8
MultiplierN/A
Non-volatile Memory4 KB
Package GroupVQFN
Package Size: mm2:W x L24VQFN: 9 mm2: 3 x 3(VQFN) PKG
RAM1 KB
SPI1
Security EnablerCryptographic acceleration,Debug security,Physical security,Secure FW and SW update,Software IP protection
Special I/ON/A
Standby Power1 LPM3-uA
Timers - 16-bit1
UART1
Wakeup Time10 us
  • Evaluation Modules & Boards: MSP-FET430U20
    MSP-FET + MSP-TS430PW20 FRAM Microcontroller Development Kit Bundle (Microcontrollers not Included)
  • Evaluation Modules & Boards: MSP-TS430PW20
    Target Development Board for MSP430FR2000, MSP430FR21x and MSP430FR23x MCUs - 20-pin
  • Evaluation Modules & Boards: MSP-EXP430FR2311
    MSP430FR2311 LaunchPad Development Kit
  • Software I2C Master and Slave on MSP430FR2111
    PDF, 348 Кб, Файл опубликован: 10 авг 2016
    The MSP430FR2111 is an FRAM-based low-pin-count (16 pins) microcontroller of the MSP430FRx family. Because of its low pin count, the hardware I2C module is not integrated in this MCU. This application report describes a software-based I2C solution for the MSP430FR2111 MCU. Both software I2C master and slave solutions are implemented using a small amount of MCU resources. The interface to the I2C b
  • Single-Wire Communication Host With MSP430в„ў MCUs
    PDF, 134 Кб, Файл опубликован: 15 сен 2017
  • Stepper Motor Control Using MSP430в„ў MCUs
    PDF, 70 Кб, Файл опубликован: 26 сен 2017
  • Low -Power Hex Keypad Using MSP430в„ў MCUs
    PDF, 84 Кб, Файл опубликован: 27 сен 2017
  • Servo Motor Controller Using MSP430в„ў MCUs
    PDF, 87 Кб, Файл опубликован: 27 сен 2017
  • Programmable Frequency Locked Loop Using MSP430в„ў MCUs
    PDF, 78 Кб, Файл опубликован: 27 сен 2017
  • Programmable Clock Source Using MSP430в„ў MCUs
    PDF, 62 Кб, Файл опубликован: 28 сен 2017
  • Programmable System Wake-up Controller Using MSP430в„ў MCUs
    PDF, 66 Кб, Файл опубликован: 27 сен 2017
  • UART Software Controlled RGB LED Color Mixing With MSP430в„ў MCUs
    PDF, 164 Кб, Файл опубликован: 15 сен 2017
  • EEPROM Emulation Using Low Memory MSP430в„ў FRAM MCUs
    PDF, 132 Кб, Файл опубликован: 15 сен 2017
  • External Programmable Watchdog Timer Using MSP430в„ў MCUs
    PDF, 132 Кб, Файл опубликован: 26 сен 2017
  • External RTC With Backup Memory Using a Low Memory MSP430в„ў MCU
    PDF, 82 Кб, Файл опубликован: 15 сен 2017
  • VLO Calibration on the MSP430FR4xx and MSP430FR2xx Family (Rev. A)
    PDF, 78 Кб, Версия: A, Файл опубликован: 19 фев 2016
    MSP430FR4xx and MSP430FR2xx (FR4xx/FR2xx) family microcontrollers (MCUs) provide various clock sources, including some high-speed high-accuracy clocks and some low-power low-system-cost clocks. Users can select the best balance of performance, power consumption, and system cost. The on-chip very low-frequency oscillator (VLO) is a clock source with 10-kHz typical frequency included in FR4xx/FR2xx
  • MSP430 FRAM Quality and Reliability (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 1 май 2014
    FRAM is a nonvolatile embedded memory technology and is known for its ability to be ultra-low power while being the most flexible and easy-to-use universal memory solution available today. This application report is intended to give new FRAM users and those migrating from flash-based applications knowledge on how FRAM meets key quality and reliability requirements such as data retention and endura
  • MSP430 FRAM Technology – How To and Best Practices
    PDF, 326 Кб, Файл опубликован: 23 июн 2014
    FRAM is a non-volatile memory technology that behaves similar to SRAM while enabling a whole host of new applications, but also changing the way firmware should be designed. This application report outlines the how to and best practices of using FRAM technology in MSP430 from an embedded software development perspective. It discusses how to implement a memory layout according to application-specif
  • Migrating From MSP430 F2xx and G2xx Families to MSP430 FR4xx and FR2xx Family (Rev. E)
    PDF, 237 Кб, Версия: E, Файл опубликован: 4 май 2018
    This application report helps to ease the migration from MSP430F2xx flash-based MCUs to the MSP430FR4xx and MSP430FR2xx family of FRAM-based MCUs. It discusses programming system hardware core architecture and peripheral considerations. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR4xx and MSP430FR2xx devices see the MSP430
  • General Oversampling of MSP ADCs for Higher Resolution (Rev. A)
    PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
    Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430FRxx FRAM
На английском языке: Datasheet Texas Instruments MSP430FR2111IRLLR
