Datasheet Texas Instruments LM78S40CN/NOPB — Даташит
СерияLM78
МодельLM78S40CN/NOPB
Аппаратный монитор микропроцессорной системы 16-PDIP от 0 до 70
LM78 Microprocessor System Hardware Monitor datasheet
PDF, 463 Кб, Версия: B, Файл опубликован: 14 май 2004
68 предложений от 26 поставщиков
Microfind
LM78S40CN/NOPB
от 158 ₽
LM78S40CN/NOPB
168 ₽
LM78S40CN/NOPB
727GS
LM78S40CN/NOPB
Pin16
Package TypeNFG
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаLM78S40CN
Width (мм)6.35
Length (мм)19.304
Thickness (мм)3.302
Pitch (мм)2.54
Max Height (мм)4.32
Рабочий диапазон температурот -40 до 125,0 до 70 C
Package GroupPDIP
  • Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)
    PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
  • AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)
    PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation and compensation of linear regulators.
  • AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)
    PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
    The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t
  • Understanding the Terms and Definitions of LDO Voltage Regulators
    PDF, 197 Кб, Файл опубликован: 21 окт 1999
    This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab
  • AN-1028 Maximum Power Enhancement Techniques for Power Packages (Rev. B)
    PDF, 684 Кб, Версия: B, Файл опубликован: 6 май 2013
    The purpose of this application report is to aid the user in maximizing the power handling capability of Texas Instruments power packages by using the SOT-223 as an example.
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
Серия: LM78 (2)
  • Semiconductors > Sensing Products > Monitoring & Fan Control
На английском языке: Datasheet Texas Instruments LM78S40CN/NOPB
