Клеммники KEEN SIDE
Datasheet Texas Instruments LMS8117ADT-ADJ/NOPB — Даташит
СерияLMS8117A
МодельLMS8117ADT-ADJ/NOPB
Линейный стабилизатор с фиксированным/регулируемым выходом 1 А/LDO 3-TO-252 от 0 до 125
LMS8117A 1-A Low-Dropout Linear Regulator datasheet
PDF, 651 Кб, Версия: F, Файл опубликован: 16 дек 2016
47 предложений от 20 поставщиков
Чип стабилизации напряжения, TEXAS INSTRUMENTS LMS8117ADT-ADJ/NOPB LDO Voltage Regulator, Adjustable, 2.5V to 15V in, 1.2V drop, 1.25V to 13.8V/1A out, TO-252-3...
LMS8117ADT-ADJ/NOPB
39 ₽
Рутоника
LMS8117ADT-ADJ/NOPB
51 ₽
LMS8117ADT-ADJ/NOPB
65 ₽
727GS
LMS8117ADT-ADJ/NOPB
от 171 ₽
Pin33
Package TypeNDPNDP
Industry STD TermTO-252TO-252
JEDEC CodeR-MSFM-LR-MSFM-L
Package QTY7575
CarrierTUBETUBE
МаркировкаLMS8117ADT-ADJ
Width (мм)6.16.1
Length (мм)6.586.58
Thickness (мм)2.32.3
Pitch (мм)4.574.57
Max Height (мм)2.552.55
Точность3 %
Fixed Output Options1.8,3.3 В
Iout(Max)1 A
Iq(Typ)5 мА
Рабочий диапазон температурот 0 до 125 C
PSRR @ 100KHz37 дБ
Package GroupTO-252
Package Size: mm2:W x L3TO-252: 65 mm2: 9.91 x 6.58(TO-252) PKG
Regulated Outputs1
Special FeaturesN/A
Thermal Resistance ОёJA56 В°C/W
Vdo(Typ)1200 мВ
Vin(Max)15 В
Vin(Min)2.5 В
Vout(Max)13.75 В
Vout(Min)1.5 В
  • Method For Cal Output Voltage Tolerances in Adj Regs (Rev. A)
    PDF, 284 Кб, Версия: A, Файл опубликован: 5 май 2013
    When working with voltage regulator circuits the designer is often confronted with the need to calculatethe tolerance of the regulated output voltage. For fixed voltage regulators this problem is easily managedbecause the required information is directly supplied on the semiconductor manufacturer's data sheet.
  • AN-1482 LDO Regulator Stability Using Ceramic Output Capacitors (Rev. A)
    PDF, 169 Кб, Версия: A, Файл опубликован: 25 апр 2013
    Ultra-low ESR capacitors such as ceramics are highly desirable because they can support fast-changingload transients and also bypass very high frequency noise coming from switching converter powersources which a linear regulator can not reject. However using ultra-low ESR capacitors on the output ofan LDO regulator requires that specific design changes be implemented to ensure loop stabili
LMS8117ADTADJ/NOPB, LMS8117ADT ADJ/NOPB
На английском языке: Datasheet Texas Instruments LMS8117ADT-ADJ/NOPB
