Datasheet Texas Instruments 81023012A — Даташит
СерияTL061
Модель81023012A
Маломощный операционный усилитель общего назначения с входом JFET 20-LCCC от -55 до 125
TL06xx Low-Power JFET-Input Operational Amplifiers datasheet
PDF, 2.5 Мб, Версия: L, Файл опубликован: 26 май 2015
LOW-POWER JFET-INPUT OPERATIONAL AMPLIFIERS
81023012A
ТаймЧипс
81023012A
81023012A
Pin20
Package TypeFK
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.83
Max Height (мм)2.03
Additional FeaturesVos Adj Pin
Approx. Price (US$)0.14 | 1ku
АрхитектураFET
CMRR(Min)(dB)70
CMRR(Typ)(dB)86
GBW(Typ)(MHz)1
Input Bias Current(Max)(pA)200
Iq per channel(Max)(mA)0.25
Iq per channel(Typ)(mA)0.2
Number of Channels(#)1
Offset Drift(Typ)(uV/C)10
Operating Temperature Range(C)-40 to 85
0 to 70
Output Current(Typ)(mA)10
Package GroupPDIP
SOIC
SO
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
See datasheet (PDIP)
Rail-to-RailIn to V+
Slew Rate(Typ)(V/us)3.5
Total Supply Voltage(Max)(+5V=5, +/-5V=10)36
Total Supply Voltage(Min)(+5V=5, +/-5V=10)7
Vn at 1kHz(Typ)(nV/rtHz)42
Vos (Offset Voltage @ 25C)(Max)(mV)6
RoHSНе совместим
  • Understanding Operational Amplifier Specifications
    PDF, 273 Кб, Файл опубликован: 13 июл 1998
    Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen
  • Handbook of Operational Amplifier Applications (Rev. B)
    PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
    While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd
На английском языке: Datasheet Texas Instruments 81023012A
