Datasheet Texas Instruments LP2951D — Даташит
СерияLP2951
МодельLP2951D
Микромощные регуляторы напряжения 30 В, 100 мА с отключением 8-SOIC от -40 до 125
LP295x Adjustable Micropower Voltage Regulators with Shutdown datasheet
PDF, 3.7 Мб, Версия: I, Файл опубликован: 12 ноя 2014
Package TypeD
Package QTY75
МаркировкаLP2951
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Точность3 %
Fixed Output Options3,3.3,5 В
Iout(Max)0.1 A
Iq(Typ)0.075 мА
Noise160 uVrms
PSRR @ 100KHz57 дБ
Regulated Outputs1
Special FeaturesEnable,Power Good
Thermal Resistance ОёJA52 В°C/W
Vdo(Typ)380 мВ
Vin(Max)30 В
Vin(Min)2 В
Vout(Max)29 В
Vout(Min)1.2 В
  • Evaluation Modules & Boards: LP2951EVM
    LP2951 Fixed/Adjustable Micropower Low-Dropout (LDO) Regulator Evaluation Module
  • Low-Voltage Current Loop Transmitter
    PDF, 519 Кб, Файл опубликован: 2 авг 2007
  • Extending the Input Voltage Range of an LDO Regulator
    PDF, 32 Кб, Файл опубликован: 16 авг 2002
    This application report explains how to use a FET to overcome the input voltage limitation of a linear regulator.
  • ESR Stability and the LDO Regulator
    PDF, 83 Кб, Файл опубликован: 7 май 2002
    Choosing an output capacitor for LDO regulators with PNP or PMOS pass element can be difficult to specific ESR requirements. This application note explains why higher ESR capacitors are necessary how to chose them and how to determine whether or not the regulator is stable.
  • Simple Power Solution Using LDOs for the DM365 (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 11 сен 2009
  • 3.6V - 5.5V Input LDO with Dual-Level Output Reference Design for MSP430 (Rev. A)
    PDF, 199 Кб, Версия: A, Файл опубликован: 14 июн 2010
    This reference design is presented to help application designers and others who are trying to use the MSP430 in a system with an input voltage in the range of 3.6 V to 5.5 V and who are also interested in using an easy-to-use low-dropout linear regulator (LDO) for a simple design with extended battery life by putting the MSP430 into a low-power state between operating states.
  • Battery Charging
    PDF, 146 Кб, Файл опубликован: 21 мар 2007
  • Low Power 150-mA LDO Linear Regulators. Extended Output Voltage Adjustment Range
    PDF, 41 Кб, Файл опубликован: 11 июн 1999
    The TPS76301 low-dropout (LDO) adjustable linear regulator generates a regulated 1-V output from an input voltage ranging from 3 V to 6 V. The application circuit is based on the application detailed in the TPS76301 data sheet (TI Literature number SLVS181A Figure 21) except for the auxiliary circuit which is shown here in Figure 1.
  • 3.6V - 5.5V Input LDO Reference Design for MSP430 (Rev. A)
    PDF, 110 Кб, Версия: A, Файл опубликован: 14 июн 2010
    This reference design is presented to help application designers and others who are trying to use the MSP430 in a system with an input voltage in the range of 3.6 V to 5.5 V and who are also interested in using an easy-to-use low-dropout linear regulator (LDO) for a simple design but may not be as concerned about maintaining the highest possible efficiency or longest battery life.
  • AN-1815 LDOs Ease the Stress of Start-Up (Rev. A)
    PDF, 81 Кб, Версия: A, Файл опубликован: 24 апр 2013
    The LP38851/52/53 devices with soft-start provide a reliable way to ensure that start-up into highcapacitive loads is uneventful and stress free.
  • Ceramic Capacitors Replace Tantalum Capacitors in LDOs (Rev. A)
    PDF, 44 Кб, Версия: A, Файл опубликован: 13 окт 2006
    With the proper considerations ceramic output capacitors can be used with low dropout regulators (LDO) and DC/DC switching converters that require tantulum output capacitors.
  • Understanding LDO Dropout
    PDF, 52 Кб, Файл опубликован: 9 май 2005
    Not all low dropout (LDO) linear regulator data sheets provide the voltage dropout information needed for all applications. This application report shows a designer how to use an LDO data sheet's specified dropout performance to determine the dropout voltage at other operating conditions.
  • AN-1061 Power Conversion in Line-Powered Equipment (Rev. B)
    PDF, 406 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note describes line-powered equipment and power conversion techniques or methods tosolve those typical power needs.
  • A Topical Index of TI Supply Voltage Supervisor (SVS) Application Notes
    PDF, 56 Кб, Файл опубликован: 15 июн 2015
  • Techniques for accurate PSRR measurements
    PDF, 1.9 Мб, Файл опубликован: 28 окт 2013
  • AN-1950 Silently Powering Low Noise Applications (Rev. A)
    PDF, 10.5 Мб, Версия: A, Файл опубликован: 22 апр 2013
    This application report explains how to implement a low noise switch mode power supply solution. Itintroduces the sources of noise and explain how to minimize them. A big factor in noise generation andpropagation is the printed circuit board layout. Important basics are discussed. Circuit measurementtechniques are also explained to guide a design engineer towards a low noise but efficient so
  • LDO Performance Near Dropout
    PDF, 149 Кб, Файл опубликован: 8 окт 2010
  • AN-1482 LDO Regulator Stability Using Ceramic Output Capacitors (Rev. A)
    PDF, 169 Кб, Версия: A, Файл опубликован: 25 апр 2013
    Ultra-low ESR capacitors such as ceramics are highly desirable because they can support fast-changingload transients and also bypass very high frequency noise coming from switching converter powersources which a linear regulator can not reject. However using ultra-low ESR capacitors on the output ofan LDO regulator requires that specific design changes be implemented to ensure loop stabili
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Linear and Switching Voltage Regulator Fundamental Part 1
    PDF, 183 Кб, Файл опубликован: 21 мар 2007
  • AN-1028 Maximum Power Enhancement Techniques for Power Packages (Rev. B)
    PDF, 684 Кб, Версия: B, Файл опубликован: 6 май 2013
    The purpose of this application report is to aid the user in maximizing the power handling capability of Texas Instruments power packages by using the SOT-223 as an example.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
  • Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)
    PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
  • Understanding the Terms and Definitions of LDO Voltage Regulators
    PDF, 197 Кб, Файл опубликован: 21 окт 1999
    This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
На английском языке: Datasheet Texas Instruments LP2951D
