Datasheet ТI TPA1517DWPG4 — Даташит
| Серия | TPA1517 |
| Модель | TPA1517DWPG4 |
Стерео, аудиоусилитель средней мощности класса AB 20-SO PowerPAD от -40 до 85
6-W Stereo Audio Power Amplifier datasheet
PDF, 922 Кб, Версия: D, Файл опубликован: 20 фев 2007
- Reducing And Eliminating The Class-D Output FilterPDF, 180 Кб, Файл опубликован: 24 авг 1999
This application report investigates reducing and eliminating the LC output filter traditionally used in class-D audio power amplifier applications. The filter can be completely eliminated if the designer is using a predominatly inductive speaker; however, the supply current and the EMI are higher than if using the full second-order Butterworth low-pass filter. The designer can use half of the com - Design Considerations For Class-D Audio Power AmplifiersPDF, 144 Кб, Файл опубликован: 23 авг 1999
This application report provides background information, general equations, and component selection criteria for proper design and implementation of the Texas Instruments class-D audio power amplifiers. Topics include class-D switching and charge pump circuits, signal conditioning of the audio inputs and outputs for both the class-D and class-AB headphone amplifiers, IC Control and indicator circu - Pop Reduction for the TPA1517 Audio Power AmplifierPDF, 228 Кб, Файл опубликован: 31 авг 2004
- RC Filter Box For Class-D Output Power and THD+N MeasurementPDF, 636 Кб, Файл опубликован: 20 фев 2004
- Measuring Class-D Amplifiers for Audio Speaker Overstress TestingPDF, 175 Кб, Файл опубликован: 28 окт 2005
This application report presents the results of an experiment conducted to demonstrate how to address the two most common concerns regarding speaker damage using Class-D amplifiers. - AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply. - PowerPAD Thermally Enhanced Package (Rev. H)PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
Серия: TPA1517 (7)
- HPA00892DWPR TPA1517DWP TPA1517DWPG4 TPA1517DWPR TPA1517DWPRG4 TPA1517NE TPA1517NEE4
- Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
