Datasheet Texas Instruments OPA658NB/250 — Даташит
СерияOPA658
МодельOPA658NB/250
Широкополосный операционный усилитель с обратной связью по току малой мощности 5-SOT-23
Pin5
Package TypeDBV
Industry STD TermSOT
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Рекомендуемая замена
ReplacementOPA658N/250
Replacement CodeQ
RoHSНе совместим
  • Evaluation Modules & Boards: DEM-OPA68XP
    DEM-OPA68xP: Demonstration Fixture
  • The Current-Feedback Op Amp: A High-Speed Building Block
    PDF, 117 Кб, Файл опубликован: 2 окт 2000
    Although current-feedback amplifiers (CFAs) have been in use for quite some time, there is a reluctance to view them in the same light as voltage-feedback amplifiers (VFAs). For instance, the gain-bandwidth curve of VFAs has a parallel in a transimpedance-bandwidth curve for CFAs. This parameter can be used to determine the closed-loop behavior of the CFA in same way that GBW can for the VFA. Not
На английском языке: Datasheet Texas Instruments OPA658NB/250
