Datasheet ТI OPA564AIDWD — Даташит
СерияOPA564
МодельOPA564AIDWD
Datasheet Texas Instruments OPA564AIDWD
1,5 А, 24 В, 17 МГц, операционный усилитель мощности 20-HSOP от -40 до 85
1.5A, 24V, 17MHz Power Operational Amplifier datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 28 янв 2011
  • Biasing Considerations for OPA564 During Enabled and Disabled States
    PDF, 130 Кб, Файл опубликован: 6 мар 2011
    The OPA564 is a high-voltage, high-current, wide-bandwidth operational amplifier suitable for many applications. Among the many features available on the OPA564 is a disabled mode that is designed to be used for power savings in time multiplexed systems such as powerline communications. When using an op amp that can be placed into either the enabled state or disabled state (shutdown), it is critic
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
Серия: OPA564 (4)
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA564AIDWD
Политика конфиденциальности
