Datasheet Texas Instruments BQ3285S-SB2TRG4 — Даташит
СерияBQ3285
МодельBQ3285S-SB2TRG4
Микросхема RTC с 114x8 NVSRAM 24-SOIC от 0 до 70
bq3285 - Real-Time Clock (RTC) datasheet
PDF, 603 Кб, Версия: A, Файл опубликован: 26 май 2004
Pin24
Package TypeDW
Width (мм)7.5
Length (мм)15.4
Thickness (мм)2.35
Max Height (мм)2.65
RoHSНе совместим
  • Using RAM Clear Function With bq3285/bq3287A RTCs
    PDF, 125 Кб, Файл опубликован: 5 сен 1999
    Using RAM Clear Function With bq3285/bq3287A RTCs Provides Efficient and Compact Solution
  • U-503 Using the bq3285/7E in a Green or Portable Environment
    PDF, 302 Кб, Файл опубликован: 5 сен 1999
    Using the bq3285/7E in a Green or Portable Environment Using the UCC3809 Primary Side Controller and the UCC3956 Battery Charger Controller
  • U-502 Time-Base Oscillator for RTC IC
    PDF, 313 Кб, Файл опубликован: 5 сен 1999
    Time-Base Oscillator for RTC ICs.The operation of the time-base oscillator is critical to the timekeeping functions of the bq3285, bq4285, and bq4845 series of real-time-clocks (RTCs). This application note describes some basic characteristics of the piezoelectric crystal and the on-chip crystal oscillator circuitry designed into these RTC series. It also includes suggestions for achieving timek
  • Semiconductors > Clock and Timing > Real-time Clocks
BQ3285SSB2TRG4, BQ3285S SB2TRG4
На английском языке: Datasheet Texas Instruments BQ3285S-SB2TRG4
