Datasheet Texas Instruments 5962-8852201SA — Даташит
СерияSN54AS808B
Модель5962-8852201SA
Шестнадцатеричный 2 входа и драйверы 20-CDIP от -55 до 125
Hex 2-Input And Drivers datasheet
PDF, 608 Кб, Версия: C, Файл опубликован: 1 янв 1995
Pin20
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.92
Length (мм)24.2
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Тип входаTTL
Operating Temperature Range(C)-55 to 125
Тип выходаTTL
Package GroupCDIP
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
RatingMilitary
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)(V)5.5
VCC(Min)(V)4.5
tpd @ Nom Voltage(Max)(ns)6.5
RoHSНе совместим
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Live Insertion
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Introduction to Logic
  • Semiconductors > Space & High Reliability > Logic Products > Gate Products
59628852201SA, 5962 8852201SA
На английском языке: Datasheet Texas Instruments 5962-8852201SA
