Datasheet Texas Instruments UC1825AL — Даташит
СерияUC1825A
МодельUC1825AL
Высокоскоростной ШИМ-контроллер 20-LCCC от -55 до 125
UC2823x, UC2825x, UC3823x, UC3825x: High Speed PWM Controller datasheet
PDF, 922 Кб, Версия: E, Файл опубликован: 9 сен 2010
Pin20
Package TypeFK
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Package QTY1
МаркировкаUC1825AL
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.83
Max Height (мм)2.03
Control MethodCurrent
Duty Cycle(Max)50 %
Frequency(Max)1000 kHz
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Special FeaturesError Amplifier,Leading Edge Blanking,Soft Start,Synchronization Pin,Multi-topology
TopologyBoost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off9.2/8.4 В
Vin(Max)22 В
Vin(Min)8.4 В
RoHSSee ti.com
  • U-128 The UC3823AB and UC3825AB Enhanced Generation of PWM Controllers
    PDF, 204 Кб, Файл опубликован: 5 сен 1999
    The UC3823A and B and the UC3825A and B family of PWM control ICs are improved versions of the standard UC3823 & UC3825 family. This application note describes the enhancements incorporated in four new PWM control ICs: the UC3823A UC3823B UC3825A and UC3825B. Based on the industry standard UC3823 and UC3825 controllers this advanced generation features several key improvements in protection and
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1825AL
