Datasheet Texas Instruments SN74LS145N3 — Даташит
СерияSN74LS145
МодельSN74LS145N3
Декодеры/драйверы преобразования BCD в десятичное число 16-PDIP от 0 до 70
BCD to Decimal Decoders/Drivers datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 1 мар 1974
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Approx. Price (US$)0.35 | 1ku
Bits(#)10
Channels(#)1
Configuration4:10
F @ Nom Voltage(Max)(Mhz)35
FunctionDecoder/Demultiplexer
ICC @ Nom Voltage(Max)(mA)13
Тип входаTTL
Output Drive (IOL/IOH)(Max)(mA)80/-20
Тип выходаTTL
Package GroupPDIP
Schmitt TriggerNo
Technology FamilyLS
ТипStandard
VCC(Max)(V)5.25
VCC(Min)(V)4.75
Voltage(Nom)(V)5
tpd @ Nom Voltage(Max)(ns)50
RoHSНе совместим
  • Hardware Design Considerations for a Wireless LED based Display Design
    PDF, 682 Кб, Файл опубликован: 11 июн 2014
    Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly.
  • Designing with the SN54/74LS123 (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
  • Semiconductors > Logic > Specialty Logic > Decoder/Encoder/Multiplexer
На английском языке: Datasheet Texas Instruments SN74LS145N3
