Линейка продуктов KEEN SIDE
Datasheet Texas Instruments UCC28600DR — Даташит
СерияUCC28600
МодельUCC28600DR
8-контактный квазирезонансный контроллер обратного хода зеленого режима 8-SOIC от -40 до 105
UCC28600 8-Pin Quasi-Resonant Flyback Green-Mode Controller datasheet
PDF, 1.4 Мб, Версия: K, Файл опубликован: 31 авг 2015
Package TypeD
Package QTY2500
Маркировка28600D
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Control MethodCurrent
Duty Cycle(Max)99 %
Frequency(Max)130 kHz
Frequency(Min)40 kHz
Special FeaturesSSR,QR/TM,Error Amplifier,Green Mode,Light Load Efficiency,Power Delivery Compatible,Motor Drive Compatible,Audio Compatible
UVLO Thresholds On/Off10.3/9.3 В
  • Evaluation Modules & Boards: UCC28600EVM-65W
    UCC28600 Evaluation Module
  • Design Considerations for the UCC28600 (Rev. B)
    PDF, 250 Кб, Версия: B, Файл опубликован: 1 май 2008
    The UCC28600 Quasi-Resonant Green-Mode Controller provides engineers with a cost-effective solution for designing energy efficient power supplies. Despite the 8-pin package, the device has many built-in advanced protection features. Because most of the pins on the device have dual functions, careful attention must be given to the design and layout of the circuit. What follows is a brief discuss
  • Flyback Transformer Design for the UCC28600 (Rev. A)
    PDF, 50 Кб, Версия: A, Файл опубликован: 13 апр 2011
    The flyback transformer plays a crucial role in the performance of the green-mode controller. Considerations must be given to adequate coupling for the bias windings, minimizing leakage inductance, and minimizing audible noise. All of these criteria can easily be met with proper transformer design from the start. Once the Design Calculator spreadsheet, (TI Literature Number SLVC104) , determines t
  • Compensation Design with TL431 for UCC28600
    PDF, 542 Кб, Файл опубликован: 16 янв 2013
  • Bootstrap Circuit for Green Mode Applications
    PDF, 111 Кб, Файл опубликован: 27 янв 2006
  • Q4 2009 Issue Analog Applications Journal
    PDF, 1.5 Мб, Файл опубликован: 4 окт 2009
Серия: UCC28600 (4)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Flyback Controller
На английском языке: Datasheet Texas Instruments UCC28600DR
