Datasheet Texas Instruments TPS7133QPWPLE — Даташит
СерияTPS71
МодельTPS7133QPWPLE
Стабилизатор напряжения с низким падением напряжения, 500 мА, 20-TSSOP от -40 до 125
Low-Dropout Voltage Regulators datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 22 янв 2003
Ruimeng предлагает удачную замену популярной микросхеме Axx1248 – 24-битный Σ-Δ АЦП MS5148T
Pin20
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Accuracy(%)3
Additional FeaturesEnable
Overcurrent Protection
Power Good
Thermal Shutdown
Approx. Price (US$)1.05 | 1ku
Fixed Output Options(V)3.3
4.8
5
Iout(Max)(A)0.5
Iq(Typ)(mA)0.28
Operating Temperature Range(C)-40 to 125
Output OptionsAdjustable Output
Fixed Output
Package GroupTSSOP
See datasheet (WSON)
See datasheet (SON)
Regulated Outputs(#)1
Vdo(Typ)(mV)235
Vin(Max)(V)10
Vin(Min)(V)2.5
Vout(Max)(V)9.75
Vout(Min)(V)1.2
RoHSНе совместим
  • TMS320C62x/67x Power Supply Solutions for 1-2 DSPs Using the TL5001A and TPS7133 (Rev. A)
    PDF, 190 Кб, Версия: A, Файл опубликован: 1 июн 1999
    This application report describes a low-cost power solution for Texas Instruments' TMS320C6000 DSP applications using the TL5001PWM controller and the TPS7133 low drop-out voltage regulator. The reference design included in this report uses the TL5001AEVM-122 (SLVP122) evaluation module (EVM) which is available for customer testing and evaluation.
  • Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
    This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
На английском языке: Datasheet Texas Instruments TPS7133QPWPLE
