Datasheet Texas Instruments TPS25944ARVCR — Даташит
СерияTPS25944A
МодельTPS25944ARVCR
18V, 5A, 42mО© Circuit Breaking Power MUX eFuse w/Integrated Reverse Current Protection, IMON & PG 20-WQFN -40 to 85
TPS25942x/44x 2.7 V-18 V, 5-A eFuse Power MUX With Multiple Protection Modes datasheet
PDF, 3.4 Мб, Версия: C, Файл опубликован: 18 янв 2017
Pin20
Package TypeRVC
Industry STD TermWQFN
JEDEC CodeR-PQFP-N
Package QTY3000
Маркировка25944A
Width (мм)4
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Channel(s) Controlled1
Current Limit Accuracy+/-8%
Current Limit Function EnabledStartup Only
Current Limit TypeAdjustable
Current Limit(Max)5.2 A
Current Limit(Min)0.6 A
FET ProtectionThermal
Fault ResponseAuto Retry
Imax5.2 A
Количество каналов1
ON_OFF Control InputENBLK,ENUV,OV s
Overcurrent ResponseCircuit Breaking
Overvoltage ResponseCutoff
Package GroupWQFN
Package Size: mm2:W x L20WQFN: 12 mm2: 4 x 3(WQFN) PKG
Rise Time(Typ)120 us
Ron(Typ)42 mOhm
Special FeaturesCurrent Sense/Monitor,Fault Reporting,Overvoltage Protection,Power Good,Power MUXing,Reverse Current Protection,Thermal Shutdown,Under Voltage Lock Out
UL RecognitionYes
Vabsmax_cont20 В
Vin(Max)18 В
Vin(Min)2.7 В
  • Evaluation Modules & Boards: TPS25942EVM-635
    TPS25942EVM-635 Evaluation Module for TPS25942x
Серия: TPS25944A (2)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
На английском языке: Datasheet Texas Instruments TPS25944ARVCR
