Datasheet ТI CD74ACT646M — Даташит
| Серия | CD74ACT646 |
| Модель | CD74ACT646M |
Восьмеричные неинвертирующие шинные приемопередатчики/регистры с выходами с 3 состояниями 24-SOIC от -55 до 125
Octal-Bus Transceiver/Registers, 3-State datasheet
PDF, 900 Кб, Файл опубликован: 3 дек 1998
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD74ACT646 (2)
- CD74ACT646M CD74ACT646M96
- Semiconductors > Logic > Buffer/Driver/Transceiver > Registered Transceiver
