Datasheet Texas Instruments SN74HC164N3 — Даташит
Серия | SN74HC164 |
Модель | SN74HC164N3 |
8-битные сдвиговые регистры последовательного вывода с параллельным выходом 14-PDIP от -40 до 125
SNx4HC164 8-Bit Parallel-Out Serial Shift Registers datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 3 фев 2014
Pin | 14 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Width (мм) | 6.35 |
Length (мм) | 19.3 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
3-State Output | No |
Approx. Price (US$) | 0.09 | 1ku |
F @ Nom Voltage(Max)(Mhz) | 28 |
ICC @ Nom Voltage(Max)(mA) | 0.08 |
Тип входа | CMOS |
Operating Temperature Range(C) | -40 to 125 |
Output Drive (IOL/IOH)(Max)(mA) | 5.2/-5.2 |
Тип выхода | CMOS |
Package Group | PDIP |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | HC |
VCC(Max)(V) | 6 |
VCC(Min)(V) | 2 |
Voltage(Nom)(V) | 6 |
tpd @ Nom Voltage(Max)(ns) | 38 |
RoHS | Не совместим |
- HCMOS Design Considerations (Rev. A)PDF, 207 Кб, Версия: A, Файл опубликован: 9 сен 2002
This document describes a potential problem designers may encounter when using high-speed CMOS (HC) logic devices. There also is a broad range of CMOS-system to non-CMOS-system interfaces that need to be considered. The design engineer inevitably encounters these interfaces. Key considerations for handling these interfaces are also discussed in this book.
Серия: SN74HC164 (19)
- Semiconductors > Logic > Flip-Flop/Latch/Register > Shift Register
