Datasheet Texas Instruments ADS7800BH — Даташит
СерияADS7800
МодельADS7800BH
ADS7800: 12-Bit 3-µs Sampling Analog-to-Digital Converter datasheet
PDF, 845 Кб, Версия: A, Файл опубликован: 17 фев 2004
Pin24
Package TypeJDN
Industry STD TermCDIP SB
JEDEC CodeR-CDIP-T
Package QTY1
МаркировкаADS7800BH
Width (мм)7.37
Length (мм)30.48
Thickness (мм)2.54
Pitch (мм)2.54
Max Height (мм)4.45
# Input Channels1
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)4.75 В
АрхитектураSAR
Digital Supply(Max)5.25 В
Digital Supply(Min)4.75 В
INL(Max)0.5 +/-LSB
Input Range(Max)10 В
Input Range(Min)-10 В
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceParallel
Multi-Channel ConfigurationN/A
Package Size: mm2:W x L24SOIC: 160 mm2: 10.3 x 15.5(SOIC) PKG
Power Consumption(Typ)135 mW
Reference ModeInt
Разрешение12 Bits
SINADN/A дБ
SNR73 дБ
Sample Rate (max)333kSPS SPS
Sample Rate(Max)0.333 MSPS
THD(Typ)-80 дБ
  • Using the ADS7800 12 Bit ADC with Unipolar Input Signals
    PDF, 37 Кб, Файл опубликован: 2 окт 2000
    The ADS7800 12 bit Sampling analog-to-digital-converter is designed to operate with bipolar inputs of В±5V or В±10V. With the addition of an external amplifier, the ADS7800 can be used for 10V or 20V unipolar inputs. Four unipolar input options are shown in this Bulletin.
  • A Clarification of Use of High-Speed S/H to Improve Sampling ADC Performance
    PDF, 53 Кб, Файл опубликован: 2 окт 2000
    You know it's going to be one of those days when you see the printed version of an article you wrote and realize that you have made an error in the presentation of your ideas. This is what happened to me as I read Use High Speed S/H to Improve Sampling ADC Performance (Design Update, Vol.1, No.1). This article will rectify the situation and further illuminate some important performance aspe
  • Coding Schemes Used with Data Converters (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 15 май 2015
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS7800BH
