Datasheet Texas Instruments 74ACT11002N — Даташит
Серия74ACT11002
Модель74ACT11002N
Четверные вентили положительного ИЛИ-НЕ с 2 входами 16-PDIP от -40 до 85
15 предложений от 15 поставщиков
Микросхема Логический чип, NOR Gate 4Element 2IN CMOS 16Pin PDIP
74ACT11002N
36 ₽
74ACT11002N
41 ₽
МосЧип
74ACT11002NS
Hi-Tech Circuit Group
74ACT11002N
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
Серия: 74ACT11002 (3)
  • Semiconductors > Logic > Gate > NOR Gate
На английском языке: Datasheet Texas Instruments 74ACT11002N
