Datasheet Texas Instruments LMR16006YQ3DDCTQ1 — Даташит
СерияLMR16006Y-Q1
МодельLMR16006YQ3DDCTQ1
Automotive Qualified SIMPLE SWITCHER® 40V (65V transient), 0.6A Buck Regulator with 28ОјA IQ 6-SOT-23-THIN -40 to 125
LMR16006Y-Q1 SIMPLE SWITCHER Buck Regulators With High-Efficiency ECO Mode datasheet
PDF, 1.6 Мб, Файл опубликован: 17 июн 2015
Pin6
Package TypeDDC
Industry STD TermSOT-23-THIN
Package QTY250
CarrierSMALL T&R
МаркировкаQ32Y
Width (мм)1.6
Length (мм)2.9
Thickness (мм).87
Pitch (мм).95
Max Height (мм)1.1
Control ModeCurrent Mode
Duty Cycle(Max)97 %
Iout(Max)0.6 A
Iq(Typ)0.028 мА
Package GroupSOT-23-THIN
RatingAutomotive
Regulated Outputs1
Special FeaturesEnable,Light Load Efficiency,Pre-Bias Start-Up,UVLO Adjustable
Switching Frequency(Max)2100 kHz
Switching Frequency(Min)700 kHz
ТипConverter
Vin(Max)40 В
Vin(Min)4 В
Vout(Max)36 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: LMR16006YEVM
    LMR16006YEVM 6V to 60V input, 5.0V output at 600mA Step-Down Converter
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
На английском языке: Datasheet Texas Instruments LMR16006YQ3DDCTQ1
