Datasheet Texas Instruments ADS7886SBDCKR — Даташит
СерияADS7886
МодельADS7886SBDCKR
2,35–5,25 В, 12 бит, 1 MSPS, последовательный АЦП 6-SC70 от -40 до 125
ADS7886 12-Bit, 1-MSPS, Micro-Power, Miniature SAR Analog-to-Digital Converters datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 31 авг 2016
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаBNL
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
# Input Channels1
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)2.35 В
АрхитектураSAR
Digital Supply(Max)5.25 В
Digital Supply(Min)2.35 В
INL(Max)1.25 +/-LSB
Input Range(Max)5.25 В
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceSPI
Multi-Channel ConfigurationN/A
Package GroupSC70
Package Size: mm2:W x L6SC70: 4 mm2: 2.1 x 2(SC70) PKG
Power Consumption(Typ)13.5 mW
Reference ModeSupply
Разрешение12 Bits
SINAD72.25 дБ
SNR72.25 дБ
Sample Rate (max)1MSPS SPS
Sample Rate(Max)1 MSPS
THD(Typ)-84 дБ
  • Evaluation Modules & Boards: ADS7886EVM
    ADS7886EVM Evaluation Module
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS7886SBDCKR
