Линейка продуктов KEEN SIDE
Datasheet Texas Instruments DAC121S101QCMKX/NOPB — Даташит
СерияDAC121S101-Q1
МодельDAC121S101QCMKX/NOPB
12-битный микропитательный цифро-аналоговый преобразователь RRO 6-SOT-23-THIN от -40 до 125
DAC121S101/-Q1 12-Bit Micro Power, RRO Digital-to-Analog Converter datasheet
PDF, 1.6 Мб, Версия: J, Файл опубликован: 11 сен 2015
Pin6
Package TypeDDC
Industry STD TermSOT-23-THIN
Package QTY3000
МаркировкаX61Q
Width (мм)1.6
Length (мм)2.9
Thickness (мм).87
Pitch (мм).95
Max Height (мм)1.1
Code to Code Glitch(Typ)12 nV-sec
DAC ArchitectureString
DAC Channels1
Gain Error(Max)1 %FSR
INL(Max)8 +/-LSB
InterfaceSPI
Output Range Max.5.5 mA/V
Тип выходаBuffered Voltage
Package GroupSOT-23-THIN
Package Size: mm2:W x L6SOT-23-THIN: 8 mm2: 2.8 x 2.9(SOT-23-THIN) PKG
Power Consumption(Typ)0.64 mW
RatingAutomotive
Reference: TypeExt
Разрешение12 Bits
Sample / Update Rate1.8 MSPS
Время установления8 µs
Special FeaturesN/A
Zero Code Error(Typ)15 мВ
  • Evaluation Modules & Boards: DAC121S101EVAL
    12-Bit Micro Power Digital-to-Analog Converter with Rail-to-Rail Output
  • Evaluation Modules & Boards: DAC121S101CVAL
  • AN-2001 Daisy Chaining Precision DACs (Rev. A)
    PDF, 75 Кб, Версия: A, Файл опубликован: 1 май 2013
    It is not uncommon for the system designer to face a quagmire of reconciling the system complexity withthe desire to keep the system footprint small. One specific example that often arises in the context ofsmall system footprint is the need for single master controller to communicate with a number of slavedevices. This is not much of a problem if the master controller has multiple I/O resour
Серия: DAC121S101-Q1 (2)
На английском языке: Datasheet Texas Instruments DAC121S101QCMKX/NOPB
