Datasheet ТI ADS7844E/2K5G4 — Даташит
СерияADS7844
МодельADS7844E/2K5G4
Datasheet Texas Instruments ADS7844E/2K5G4
12-битный 8-канальный аналого-цифровой преобразователь с дискретизацией последовательного вывода 20-SSOP от -40 до 85
ADS7844: 12-Bit, 8-Channel Serial Output Sampling Analog-To-Digital Converter datasheet
PDF, 750 Кб, Версия: A, Файл опубликован: 17 окт 2003
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Apply TI TSC for Various and Multiple Functions
    PDF, 316 Кб, Файл опубликован: 11 дек 2006
    This application report presents several examples showing how a touch screen controller (TSC) from Texas Instruments provides a variety of functions such as graphs, scroll bars, pressure buttons, and analog dials. A simple resistive TSC can be used to achieve all of these functions as long as they are not activated simultaneously. This application report demonstrates a few simple examples how th
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • Using the ADS7841 and ADS7844 with 15-Clock Cycles
    PDF, 188 Кб, Файл опубликован: 30 июн 2005
    This application report presents an analysis on the use of the 15-clock cycle method of operation for the ADS7841 and ADS7844 described in their respective data sheets. The advent of commercially available processors such as the TMS470 no longer restricts users from implementing the 15-clock method with simple microprocessors. This method, however, does present some challenges to the software inte
На английском языке: Datasheet Texas Instruments ADS7844E/2K5G4
Политика конфиденциальности
