Datasheet ТI ADS8380IRHPT — Даташит
| Серия | ADS8380 |
| Модель | ADS8380IRHPT |
18-разрядный последовательный АЦП 600 KSPS с опорным сигналом и униполярным псевдодифференциальным входом 28-VQFN от -40 до 85
18-Bit 600-kHz Pseudo-Diff Input MicroPower Sampling Analog-to-Digit Converter datasheet
PDF, 1.9 Мб, Версия: A, Файл опубликован: 20 дек 2004
- Using the ADS8380 with the TMS320C6713 DSPPDF, 191 Кб, Файл опубликован: 30 мар 2005
This application report presents a solution to interfacing the ADS8380 18-bit, 600-KSPS serial interface converter to the TMS320C6713 DSP. The hardware solution is made up of existing hardware: the ADS8380EVM, 'C6713 DSK, and 5-6K Interface Board. The software demonstrates how to use an EDMA and timer peripheral to collect data at 598 kHz. Discussed also are some of the key points to remember when - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: ADS8380 (3)
- ADS8380IBRHPT ADS8380IBRHPTG4 ADS8380IRHPT
