Datasheet Texas Instruments SN74LVC1G27YZPR — Даташит
СерияSN74LVC1G27
МодельSN74LVC1G27YZPR
Одиночный логический элемент положительного ИЛИ-НЕ с 3 входами, 6-DSBGA от -40 до 85
Single 3-Input Positive-NOR Gate datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 23 дек 2013
Pin6
Package TypeYZP
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
МаркировкаCUN
Width (мм).9
Length (мм)1.5
Thickness (мм)2
Pitch (мм).5
Max Height (мм).5
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeOR
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupDSBGA
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power
Sub-FamilyNOR Gate
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)20.5,7.1,5.4,3.6 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G27YZPR
