Datasheet Texas Instruments TPA6120A2DWPR — Даташит
СерияTPA6120A2
МодельTPA6120A2DWPR
Высококачественный стереоусилитель для наушников 20-SO PowerPAD от -40 до 85
TPA6120A2 High Fidelity Headphone Amplifier datasheet
PDF, 2.4 Мб, Версия: B, Файл опубликован: 4 фев 2015
Pin20
Package TypeDWP
Industry STD TermHSOIC
Package QTY2000
Маркировка6120A2
Width (мм)7.52
Length (мм)12.82
Thickness (мм)2.55
Max Height (мм)2.65
Analog Supply (V)30 Min
АрхитектураClass-AB
Headphone ChannelsStereo
Iq per channel(Typ)11.5 мА
Load(Min)8 ohms
Выходная мощность1.5 W
PSRR75 дБ
Package GroupSO PowerPAD
Package Size: mm2:W x L20SO PowerPAD: 133 mm2: 10.405 x 12.825(SO PowerPAD) PKG
Shutdown Current (ISD)0.7 uA
Volume ControlNo
  • Evaluation Modules & Boards: TPA6120A2RGYEVM
    TPA6120A2RGYEVM Stereo Headphone Amplifier in QFN Evaluation Module
  • Evaluation Modules & Boards: TPA6120A2EVM
    TPA6120A2 Evaluation Module (EVM)
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Headphone Amplifier
На английском языке: Datasheet Texas Instruments TPA6120A2DWPR
