Datasheet Texas Instruments REG101UA-2.8/2K5 — Даташит
СерияREG101
МодельREG101UA-2.8/2K5
LDO с одним выходом, 100 мА, регулируемое/фиксированное (2,5–5,5 В), низкий уровень шума, быстрый переходный процесс, 8-SOIC, от -40 до 85
DMOS 100mA Low-Dropout Regulator datasheet
PDF, 985 Кб, Версия: D, Файл опубликован: 8 сен 2005
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Accuracy(%)2.7
Additional FeaturesEnable
Fast Transient Response
Foldback Overcurrent Protection
Thermal Shutdown
Approx. Price (US$)0.92 | 1ku
Fixed Output Options(V)2.5
2.8
2.85
3
3.3
5
Iout(Max)(A)0.1
Iq(Typ)(mA)0.4
Noise(uVrms)23
Operating Temperature Range(C)-40 to 85
Output Capacitor TypeCap Free
Ceramic
Output OptionsAdjustable Output
Fixed Output
PSRR @ 100KHz(dB)46
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Regulated Outputs(#)1
Vdo(Typ)(mV)60
Vin(Max)(V)10
Vin(Min)(V)1.8
Vout(Max)(V)5.5
Vout(Min)(V)2.5
RoHSНе совместим
  • Evaluation Modules & Boards: TPS79328EVM
    TPS79328 Evaluation Module
  • Evaluation Modules & Boards: TPS76XXXEVM-125
    TPS76xxxEVM-125 Universal SOT-23 LDO Evaluation Module
  • Evaluation Modules & Boards: TPS76933EVM-127
    SOT23 LDO, 5 V to 1.0 V, 100mA output power supply
  • Evaluation Modules & Boards: DEM-SOT23LDO
    DEM-SOT23LDO Compatible with Most Positive-Output LDO Regulators in 5- or 6-Lead SOT23 (DBV) Pkg
  • Evaluation Modules & Boards: TPS76901EVM-127
    SOT23 LDO, 5 V to 1.8 V, 100mA output power supply
  • Evaluation Modules & Boards: TPS79301EVM
    TPS79301 Evaluation Module
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
REG101UA2.8/2K5, REG101UA 2.8/2K5
На английском языке: Datasheet Texas Instruments REG101UA-2.8/2K5
