Datasheet Texas Instruments UCC3809PW-2G4 — Даташит
СерияUCC3809-2
МодельUCC3809PW-2G4
Контроллер первичной стороны эконом-класса 8-TSSOP от 0 до 70
Economy Primary Side Controller datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 19 ноя 2004
Чип стабилизации напряжения, Economy Primary Side PWM Controller 1MHz 1Out 8Pin TSSOP Tube
UCC3809PW-2G4
73 ₽
UCC3809PW-2G4
112 ₽
UCC3809PW-2G4
ТаймЧипс
UCC3809PW-2G4
Package TypePW
Industry STD TermTSSOP
Package QTY150
Маркировка38092
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Control MethodCurrent,Feedforward,Voltage
Duty Cycle(Max)70 %
Frequency(Max)1000 kHz
Gate Drive(Typ)0.8 A
Package GroupTSSOP
Special FeaturesMulti-topology,Soft Start
TopologyBoost,Buck,Flyback,Forward
UVLO Thresholds On/Off15/8 В
Vin(Max)19 В
Vin(Min)8 В
  • Evaluation Modules & Boards: UCC3809EVM
    UCC3809 Evaluation Module
  • Programming the UCC3809 for 90% Maximum Duty Cycle Clamp
    PDF, 44 Кб, Файл опубликован: 4 июн 2001
    Normally, the UCC3809 programmable duty cycle clamp feature is limited to 70% maximum duty cycle. The described technique shows how the maximum duty cycle clamp can be programmed to achieve a 90% on-time of the switching period.
  • Current balancing in four-pair, high-power PoE applications
    PDF, 269 Кб, Файл опубликован: 18 май 2007
  • U-168 Implementing a Practical Off-line Lithium-Ion Charger Using the UCC3809
    PDF, 579 Кб, Файл опубликован: 5 сен 1999
    The UCC3809 family of BCDMOS economy low-power integrated circuits contains all the control and drive circuitry required for off-line and isolated DC-to-DC fixed-frequency current-mode switching power supplies with minimal external parts count. The UCC3956 family of Switch-Mode Lithium-Ion Battery Charger Controllers accurately controls lithium-ion battery charging with a highly efficient average
  • DN-89 Comparing the UC3842, UCC3802, and UCC3809 Primary Side PWM Controllers
    PDF, 75 Кб, Файл опубликован: 5 сен 1999
    Despite the fact that the UC3842 and the UCC3802 PWM Controllers are pin-for-pin compatible, they are not drop-in replacements for each other. Designed as the next generation '42, the UCC3809 also has differences that prevent a simple drop-in substitute. This design note will help the user change from either the UC3842 or the UCC3802 to the UCC3809 in an existing design. A table identifies the mos
  • U-165 Design Rvw: Isolated 50 W Flyback Converter Using UCC3809 and UC3965
    PDF, 266 Кб, Файл опубликован: 5 сен 1999
    The flyback power stage is a popular choice for single and multiple output DC-to-DC converters at power levels of 150W or less. Without the output inductor required in buck-derived topologies, such as the forward or push-pull converter, the component count and cost are reduced. This application note will re-view the design procedure for the power stage and control electronics of a flyback converte
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
UCC3809PW2G4, UCC3809PW 2G4
На английском языке: Datasheet Texas Instruments UCC3809PW-2G4
