Datasheet Texas Instruments UCC38C41DRG4 — Даташит
СерияUCC38C41
МодельUCC38C41DRG4
BiCMOS ШИМ-контроллер с малым током 8-SOIC 0–70
UCCx8C4x BiCMOS Low-Power Current-Mode PWM Controller datasheet
PDF, 3.8 Мб, Версия: G, Файл опубликован: 10 янв 2017
IC REG CTRLR MULT TOPOLOGY 8SOIC. Boost, Flyback, Forward Converter Regulator Positive Output Step-Up, Step-Up/Step-Down DC-DC Controller IC 8-SOIC. PMIC -...
UCC38C41DRG4
69 ₽
UCC38C41DRG4
75 ₽
UCC38C41DRG4
82 ₽
UCC38C41DRG4
Package TypeD
Package QTY2500
Маркировка38C41
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Control MethodPeak Current Mode
Duty Cycle(Max)50 %
Frequency(Max)1000 kHz
Frequency(Min)26 kHz
Gate Drive(Typ)1 A
Special FeaturesError Amplifier,Multi-topology
TopologyBoost,Buck,Buck-Boost,Flyback,Forward
UVLO Thresholds On/Off7/6.6 В
Vin(Max)400 В
Vin(Min)7 В
  • UCC38C44 12-V Isolated Bias Supply (Rev. A)
    PDF, 324 Кб, Версия: A, Файл опубликован: 9 окт 2008
    This reference design describes a discontinuous, peak current-mode flyback converter whose input voltage is generated from the output of a universal power factor correction circuit. The converter is designed to operate at a switching frequency of 225 kHz, requires minimal parts, and supports an isolated 12-V, 3-W output and a non-isolated 12-V, 1-W output ideally suited for chip bias and voltage f
  • UCC38C42 25-W Forward Converter
    PDF, 320 Кб, Файл опубликован: 6 сен 2002
    This reference design presents a self-resonant reset forward converter using the UCC38C42 BiCMOS Low-Power Current-Mode PWM Controller. The input voltage for this converter is compatible with the telecom input voltage range of 36 VDC to 72 VDC. The converter is designed to operate at a switching frequency of 525 kHz, requires minimal parts, and supports an isolated 2.5-V 10-A output. The complete
  • UCC38C42 Family of High-Speed BiCMOS Current-Mode PWM Controllers
    PDF, 280 Кб, Файл опубликован: 7 фев 2002
    Since their introduction in the mid 1980?s the bipolar UC3842 family of Pulse width modulation (PWM)controllers has grown to become the most widely-used control strategy in the power supply industry. [1] The reasons for success are quite clear the devices feature an elegantly simple yet very effective control architecture they use only 8 pins they can drive MOSFET gates directly and they offer
  • U-111 Practical Considerations in Current Mode Power Supplies
    PDF, 787 Кб, Файл опубликован: 5 сен 1999
    This application note explains the numerous PWM functions and ways to maximize their usefulness. It covers practical circuit design considerations such as slope compensation gate drive circuitry external control functions synchronization and paralleling current-mode controlled modules. Circuit diagrams and simplified equations are included.
  • DN-42A Design Considerations for Transitioning from UC3842 to the New UCC3802
    PDF, 42 Кб, Файл опубликован: 5 сен 1999
    The UCC3802 offers numerous advantages that allow the power supply design engineer to meet requirements for lower power for battery-operated equipment higher switching frequencies for reduced magnetics size higher levels of circuit integration for improved reliability and lower cost. The UCC3802 family of devices is pin-out compatible with the UC3842 and UC3842A families; however it is not plu
  • Conditioning a Switch-mode Power Supply Current Signal Using TI Op Amps
    PDF, 61 Кб, Файл опубликован: 23 мар 2000
    The switch-mode power supply primary current is often sensed using a power resistor. Using an op amp to amplify the current-sense signal can reduce cost and improve noise performance and efficiency. This report reviews the advantages of using an op amp circuit and analyzes the design criteria needed to choose the proper op amp.
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: UCC38C41 (6)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC38C41DRG4
