Datasheet Texas Instruments OPA861IDBVT — Даташит
СерияOPA861
МодельOPA861IDBVT
Широкополосный операционный усилитель крутизны 6-SOT-23 от -40 до 85
Wide Bandwidth Operational Transconductance Amplifier (OTA) datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 14 май 2013
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаNSR
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Acl, min spec gain1 V/V
BW @ Acl80 МГц
GBW(Typ)400 МГц
IIB(Max)1000 нА
Iq per channel(Max)5.4 мА
Количество каналов1
Output Current(Typ)15 мА
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Slew Rate(Typ)900 V/us
Vn at Flatband(Typ)2.4 нВ/rtГц
Vos(Max)12 мВ
Vs(Max)12.6 В
Vs(Min)4 В
  • Evaluation Modules & Boards: DEM-OTA-SO-1A
    Unpopulated PCB Compatible w/Wide Bandwidth Transconductance Op Amps in 8-lead SOIC (D) Pkg
  • Demystifying the Operational Transconductance Amplifier (Rev. A)
    PDF, 259 Кб, Версия: A, Файл опубликован: 16 апр 2013
    Operational transconductance amplifiers (OTAs) are often among the least understood analog components. However, these devices serve a very useful function that is being implemented on a regular basis in many integrated circuits as an element for more advanced purposes; the current feedback amplifier is among the most prominent example. The purpose of this application report is to show how this bui
  • Semiconductors > Amplifiers > Special Function Amplifiers > Transconductance Amplifiers
На английском языке: Datasheet Texas Instruments OPA861IDBVT
