Datasheet Texas Instruments UCC3912PWPG4 — Даташит
СерияUCC3912
МодельUCC3912PWPG4
0–3 А, 3–8 В, одиночная микросхема с возможностью горячей замены, Hi-Side MOSFET, коммерческая темп.
Programmable Hot Swap Power Manager datasheet
PDF, 869 Кб, Версия: D, Файл опубликован: 17 окт 2003
IC HOT SWAP CTRLR GP 24HTSSOP. Hot Swap Controller 1 Channel General Purpose 24-HTSSOP. PMIC - Hot Swap Controllers
UCC3912PWPG4
от 917 ₽
UCC3912PWPG4
UCC3912PWPG4
UCC3912PWPG4
24-ТССОП от 0 до 70
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY60
МаркировкаUCC3912PWP
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Current Limit Accuracy+/- 40%
Current Limit Function EnabledAlways
Current Limit TypeAdjustable
Current Limit(Max)4 A
Current Limit(Min)1 A
FET ProtectionThermal
Fault ResponseAuto Retry
Imax4 A
Количество каналов1
ON_OFF Control InputSHTDWN/ s
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Ron(Typ)150 mOhm
Special FeaturesAdjustable Rise Time,Digital/I2C Compatible,Fault Reporting,Thermal Shutdown,Undervoltage Protection
Vabsmax_cont8 В
Vin(Max)8 В
Vin(Min)3 В
  • U-151 UCC3912 Integrated Electronic Circuit Breaker IC for Hot-Swap
    PDF, 380 Кб, Файл опубликован: 5 сен 1999
    This application note describes the design and performance characteristics of the UCC3912 Electronic Circuit Breaker. The practical aspects of applying the circuit breaker are discussed as well as its performance compared to that of other technologies. The UCC3912 integrates a power MOSFET with all of the necessary control and housekeeping functions, including current limiting, short-circuit prote
  • DN-68 Paralleling UCC3912 Electronic Circuit Breaker ICs
    PDF, 172 Кб, Файл опубликован: 5 сен 1999
    The UCC3912 IC is an integrated 3A electronic circuit breaker that includes programmable overcurrent protection and retry timing following a fault. Other common uses for this function are in higher current (12A) and low "headroom" applications where a lower voltage drop is required. This design note explains how to parallel the UCC3912 for each of these uses.
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
На английском языке: Datasheet Texas Instruments UCC3912PWPG4
