Datasheet Texas Instruments TPS65983BAZQZR — Даташит
Серия | TPS65983B |
Модель | TPS65983BAZQZR |
Универсальный контроллер USB Type-C™ и Power Delivery (PD) 3.0 96-BGA MICROSTAR JUNIOR от -10 до 85
TPS65983B USB Type-C and USB PD Controller, Power Switch, and High Speed Multiplexer datasheet
PDF, 2.7 Мб, Версия: A, Файл опубликован: 19 окт 2016
Pin | 96 |
Package Type | ZQZ |
Industry STD Term | BGA MICROSTAR JUNIOR |
JEDEC Code | S-PBGA-N |
Package QTY | 2500 |
Carrier | LARGE T&R |
Width (мм) | 6 |
Length (мм) | 6 |
Thickness (мм) | 0.74 |
Pitch (мм) | 0.5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Alternate Mode | Yes |
Configuration | N/A |
Data Role | DFP,DRD,UFP |
Dead Battery Support | Yes |
External Power Path Control | GPIO,NFET |
Function | CC Controller,PD Controller,Passive Signal Switch,Power Switch |
Internal Power Path | 20V 3A Source/Sink,5V 3A Source,5V 600mA VCONN |
Iq(Typ) | 58 uA |
Рабочий диапазон температур | от -10 до 85 C |
Package Group | BGA MICROSTAR JUNIOR |
Policy Manager | Integrated |
Power Role | DRP,Sink,Source |
Rating | Catalog |
Realtime VBUS monitoring | No |
USB Speed | 480 Mbps |
- Evaluation Modules & Boards: TPS65983EVM
TPS65983 USB Type-C and USB PD Controller Power Switch and High-Speed Multiplexer Evaluation Module
- USB Power Delivery - Compliance TestsPDF, 3.3 Мб, Файл опубликован: 26 апр 2017
The USB Power-Delivery Certification process requires all PD end-products using Texas Instruments'TPS6598x to comply with the USB-IF's deterministic and communication-engine MOI in addition tovarious other load and signaling tests. This application report explains the setup of three extensively usedUSB-PD testers and configuration of the PD Vendor Information File as per the product's PD fe
Серия: TPS65983B (1)
- TPS65983BAZQZR
- Semiconductors > Interface > USB > USB Type-C and Power Delivery
