Datasheet Texas Instruments UC1825L — Даташит
| Серия | UC1825 |
| Модель | UC1825L |
Высокоскоростной ШИМ-контроллер 20-LCCC от -55 до 125
High Speed PWM Controller datasheet
PDF, 2.1 Мб, Версия: A, Файл опубликован: 24 фев 2004
Купить UC1825L на РадиоЛоцман.Цены — от 824 до 8 844 ₽15 предложений от 15 поставщиков Микросхема Контроллер PWM, Current Mode PWM Controller 1.5A 1000kHz 20Pin CLLCC Tube | |||
| UC1825L Unitrode | 2 417 ₽ | ||
| UC1825L Texas Instruments | 2 539 ₽ | ||
| UC1825L883B Texas Instruments | по запросу | ||
| UC1825L Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | FK |
| Industry STD Term | LCCC |
| JEDEC Code | S-CQCC-N |
| Package QTY | 1 |
| Carrier | TUBE |
| Маркировка | UC1825L |
| Width (мм) | 8.89 |
| Length (мм) | 8.89 |
| Thickness (мм) | 1.83 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.03 |
| Mechanical Data | Скачать |
| Control Method | Current |
| Duty Cycle(Max) | 80 % |
| Frequency(Max) | 1000 kHz |
| Frequency(Min) | 0.1 kHz |
| Рабочий диапазон температур | от -55 до 125 C |
| Package Group | LCCC |
| Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
| Rating | Military |
| Special Features | Error Amplifier,Soft Start,Synchronization Pin,Multi-topology |
| Topology | Boost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull |
| UVLO Thresholds On/Off | 9.2/8.4 В |
| Vin(Max) | 30 В |
| Vin(Min) | 8.4 В |
| RoHS | See ti.com |
- U-110 1.5 Mhz Current Mode IC Controlled 50-Watt Power SupplyPDF, 298 Кб, Файл опубликован: 5 сен 1999
The UC3825 family of PWM control ICs is optimized for high-frequency switched-mode power-supply applications. This application note describes the development of a 1.5 MHz current-mode IC-controlled 50W power supply. Push-pull topology is used for this DC-to-DC converter application of +48V input to +5V at 10A output. Increases in switching speed and dynamic performance are made possible by the U - U-111 Practical Considerations in Current Mode Power SuppliesPDF, 787 Кб, Файл опубликован: 5 сен 1999
This application note explains the numerous PWM functions and ways to maximize their usefulness. It covers practical circuit design considerations such as slope compensation gate drive circuitry external control functions synchronization and paralleling current-mode controlled modules. Circuit diagrams and simplified equations are included.
Серия: UC1825 (8)
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
