Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPA6120A2RGYR — Даташит
СерияTPA6120A2
МодельTPA6120A2RGYR
Высококачественный стереоусилитель для наушников 14-VQFN от -40 до 85
TPA6120A2 High Fidelity Headphone Amplifier datasheet
PDF, 2.4 Мб, Версия: B, Файл опубликован: 4 фев 2015
Pin14
Package TypeRGY
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Маркировка6120A2
Width (мм)3.5
Length (мм)3.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Analog Supply (V)30 Min
АрхитектураClass-AB
Headphone ChannelsStereo
Iq per channel(Typ)11.5 мА
Load(Min)8 ohms
Выходная мощность1.5 W
PSRR75 дБ
Package GroupVQFN
Package Size: mm2:W x L14VQFN: 12 mm2: 3.5 x 3.5(VQFN) PKG
Shutdown Current (ISD)0.7 uA
Volume ControlNo
  • Evaluation Modules & Boards: TPA6120A2RGYEVM
    TPA6120A2RGYEVM Stereo Headphone Amplifier in QFN Evaluation Module
  • Evaluation Modules & Boards: TPA6120A2EVM
    TPA6120A2 Evaluation Module (EVM)
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Headphone Amplifier
На английском языке: Datasheet Texas Instruments TPA6120A2RGYR
