Datasheet Texas Instruments TMP108AIYFFT — Даташит
СерияTMP108
МодельTMP108AIYFFT
1.4V-Capable В±0.75В°C Temperature Sensor with Window Alert Function and I2C/SMBus in WCSP 6-DSBGA -40 to 125
Low-Power Digital Temperature Sensor with Two-Wire Interface in WCSP datasheet
PDF, 803 Кб, Файл опубликован: 18 апр 2013
Pin6
Package TypeYFF
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаT8
Thickness (мм).535
Pitch (мм).4
Max Height (мм).625
Addresses4
InterfaceI2C, SMBus, 2-Wire
Iq(Typ)6 uA
Local Sensor Accuracy(Max)0.75 +/- C
Package GroupDSBGA
Special FeaturesProgrammable Alert,Fault Queue,One-Shot Conversion,Window Comparator,Shutdown
Supply Current(Max)6 uA
Supply Current(Typ)6 uA
Supply Voltage(Max)3.6 В
Supply Voltage(Min)1.4 В
Temp Resolution(Max)12 bits
  • Evaluation Modules & Boards: TMP108EVM
    TMP108EVM - Evaluate TMP108 Digital Temperature Sensor with Two-Wire Interface in WCSP
  • Temperature sensors: PCB guidelines for surface mount devices (Rev. A)
    PDF, 5.6 Мб, Версия: A, Файл опубликован: 18 янв 2019
    Power hungry electronic components such as CPUs GPUs or FPGAs as well as voltage regulators heat up during operation. Some applications require ambient air temperature measurements while others need to measure the temperature of a nearby component on the PCB. Measuring ambient air temperature with a surface mount technology (SMT) device is challenging due to the thermal influence of other compo
  • AN-1112 DSBGA Wafer Level Chip Scale Package (Rev. AG)
    PDF, 13.7 Мб, Версия: AG, Файл опубликован: 12 авг 2015
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TMP108 (2)
  • Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
На английском языке: Datasheet Texas Instruments TMP108AIYFFT
