Datasheet Texas Instruments 5962-0051206QPA — Даташит
СерияTLV2462AM
Модель5962-0051206QPA
Двойной маломощный операционный усилитель ввода/вывода с Rail-to-Rail 8-CDIP от -55 до 125
Pin88
Package TypeJGJG
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
Маркировка0051206QPATLV2462AM
Width (мм)6.676.67
Length (мм)9.69.6
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Approx. price19.617 | 100u US$
АрхитектураBipolar
CMRR(Min)71 дБ
CMRR(Typ)85 дБ
Основные особенностиN/A
GBW(Typ)6.4 МГц
Input bias current(Max)14000 pA
Input bias current(Typ)1300 pA
Iq per channel(Max)0.65 мА
Iq per channel(Typ)0.55 мА
Number of channels2
Offset drift(Typ)2 uV/C
Operating temperature range-55 to 125 C
Output current(Typ)80 мА
Output swing headroom (to negative supply)(Typ)0.2 В
Output swing headroom (to positive supply)(Typ)-0.2 В
Package GroupCDIP|8,CFP|10,LCCC|20
Package size: mm2:W x L8CDIP: 64 mm2: 6.67 x 9.6 (CDIP|8),10CFP: 40 mm2: 6.35 x 6.35 (CFP|10),20LCCC: 79 mm2: 8.89 x 8.89 (LCCC|20) PKG
Rail-to-railIn,Out
RatingCatalog,Military
Slew rate(Typ)1.6 V/us
Total supply voltage(Max)6 +5V=5, +/-5V=10
Total supply voltage(Min)2.7 +5V=5, +/-5V=10
Vn at 1 kHz(Typ)11 нВ/rtГц
Vos (offset voltage @ 25 C)(Max)1.5 мВ
RoHSНе совместим
  • Semiconductors > Analog and Mixed-Signal > Amplifiers > Operational amplifiers (op amps) > General-purpose op amps
59620051206QPA, 5962 0051206QPA
На английском языке: Datasheet Texas Instruments 5962-0051206QPA
