Datasheet Texas Instruments LMH7322SQE/NOPB — Даташит
СерияLMH7322
МодельLMH7322SQE/NOPB
Двойной высокоскоростной компаратор 700 пс с выходами RSPECL 24-WQFN от -40 до 125
LMH7322 Dual 700 ps High Speed Comparator with RSPECL Outputs datasheet
PDF, 948 Кб, Версия: I, Файл опубликован: 18 мар 2013
Pin24
Package TypeRTW
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаL7322SQ
Width (мм)4
Length (мм)4
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Input Bias Current (+/-)(Max)5000 нА
Iq per channel(Max)15 мА
Количество каналов2
Тип выходаRSPECL
Package GroupWQFN
Package Size: mm2:W x L24WQFN: 16 mm2: 4 x 4(WQFN) PKG
Propagation Delay Time0.0007 uS
Rail-to-RailNo
Special FeaturesStrobe
VICR(Max)10.5 В
VICR(Min)0.2 В
Vos (Offset Voltage @ 25C)(Max)8 мВ
Vs(Max)12 В
Vs(Min)2.7 В
  • Evaluation Modules & Boards: LMH7322EVAL
    LMH7322 Dual 700ps High Speed Comparator with RSPECL Outputs Evaluation Board
  • Interface Circuits for TIA/EIA-644 (LVDS) (Rev. B)
    PDF, 69 Кб, Версия: B, Файл опубликован: 16 сен 2002
    This design note provides information concerning the designing of TIA/EIA-644 interface circuits. The TIA/EIA-644 standard is discussed including electrical characteristics, interconnections, line termination, and noise immunity. Finally, eye patterns are used to measure the effects of signal distortion, noise, signal attenuation, and the resultant intersymbol interference (ISI) in a data transmis
  • Interfacing Different Logic with LVDS Receivers
    PDF, 197 Кб, Файл опубликован: 14 май 2001
    This application report provides explanations and design considerations for interfacing RS-422, differential current mode logic (CML), differneital emitter coupled logic (ECL), and single-ended drivers with low-voltage differential signal (LVDS) receivers.
Серия: LMH7322 (3)
  • Semiconductors > Amplifiers > Comparators
На английском языке: Datasheet Texas Instruments LMH7322SQE/NOPB
