Datasheet Texas Instruments TPS61061DRBR — Даташит
СерияTPS61061
МодельTPS61061DRBR
Переключатель 19 В, 400 мА, повышающий преобразователь 1 МГц с регулировкой яркости для блоков питания белых светодиодов 8-SON от -40 до 85
TPS6106x Constant Current LED Driver With Digital and PWM Brightness Control datasheet
PDF, 982 Кб, Версия: B, Файл опубликован: 9 дек 2014
Package TypeDRB
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаAQQ
Width (мм)3
Length (мм)3
Thickness (мм).88
Max Height (мм)1
Количество каналов1
Duty Cycle(Max)95 %
LED4
LED Current Per Channel50 мА
Package GroupSON
Package Size: mm2:W x LSee datasheet (SON) PKG
Peak Efficiency82 %
Shutdown Current(Typ)1 uA
Special FeaturesLoad Disconnect During Shutdown
Switching Frequency(Max)1200 kHz
TopologyBoost
ТипInductive
Vin(Max)6 В
Vin(Min)2.7 В
Vout(Max)19 В
Vout(Min)2.7 В
  • Evaluation Modules & Boards: TPS61061EVM-091
    TPS6106x Evaluation Module
  • TPS61060 Dynamic Voltage Adjustment
    PDF, 223 Кб, Файл опубликован: 6 окт 2006
    The TPS61060, TPS61061, and TPS61062 are efficient white light-emitting diode (WLED) drivers. These ICs also can be configured as a constant voltage power supply. When in constant voltage mode, the TPS6106x family provides the capability for dynamic voltage scaling. This application report shows the user how to configure the IC for dynamic voltage scaling.
  • TPS61060/61/62: Single-Wire Digital Brightness Control
    PDF, 289 Кб, Файл опубликован: 5 май 2006
    The TPS6106x features a simple digital interface to allow brightness control using a single wire to control the converter. This application report shows the circuit configuration and the programming of the interface.
  • TPS61060 Voltage Regulation Mode
    PDF, 135 Кб, Файл опубликован: 10 окт 2006
    The TPS61060, TPS61061, and TPS61062 are efficient white light-emitting diodes (WLED) drivers. The standard mode of operation is to regulate a constant current through a string of WLEDs, but these ICs can also operate as a standard constant output voltage supply. This document shows the user how to configure the TPS6106x to generate a constant output voltage. It also provides guidelines on the app
  • Powering Multiple White LEDs, PWM & Digital Dimming Control Using TPS61060/1/2
    PDF, 121 Кб, Файл опубликован: 13 июн 2006
    The TPS61060/1/2 are inductive, high-frequency, synchronous boost converters with a constant current output to drive up to 5 white LEDs. The reference design and application examples shown in this document implement the TPS6106x devices powering multiple white LEDs, a digital brightness control application, and an example of an efficiency measurement setup.
  • Drive High Current LEDs
    PDF, 437 Кб, Файл опубликован: 25 янв 2007
    This application report presents high-current LED driving requirements that use the TI integrated boost converter IC TPS6106x and integrated buck converter IC bqSWITCHERв„ў (bq2410x/11x/12x). Step-by-step design procedures, measurement results, and two dimming methods are provided and discussed.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
Серия: TPS61061 (4)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS61061DRBR
